It is currently Fri Aug 22, 2025 2:09 am
 Post subject: Unclogging the reamer
PostPosted: Fri Jul 05, 2013 5:19 pm
I know that this sounds trivial, but when I'm reaming for bridge pins, I spend more time and energy picking and unclogging wood trapped in the reamer than actual reaming. Any old tricks to help alleviate the reamer from clogging up after 3 or 4 turns? Clinton
PostPosted: Fri Jul 05, 2013 5:39 pm
No old triks I'm afraid.
I just use a large bamboo BBQ skewer and only turn a couple of turns between cleans. 3/4 turns sounds a lot, the flutes must be well hard packed. (I use SM's reamers)
I suspect a rub with beeswax would not hurt if you don't intend finishing the bridge.
PostPosted: Fri Jul 05, 2013 5:50 pm
Last Name: Kincheloe
Ah, so I'm not the only one this happens to :) I just take my trusty dull x-acto knife and run it down each groove, starting from the handle and going toward the tip. Usually lifts all the compacted wood chips out with minimal effort. But do be careful not to rub it against the actual cutting edges, so as not to dull them.
You can also use a pointy piece of wood, but push from tip to handle so you're not compressing the dust into a tighter space, since it doesn't get up underneath the wood chips as well as the knife. No danger of dulling the reamer, but also doesn't work as well, especially when the wood chips are tightly compacted.
IME, you don't have to clean it out every 4 turns. Just once or twice per peg. But it's still kind of a pain.
I'm glad I don't own any spiral reamers.
PostPosted: Sun Jul 07, 2013 9:22 am
First name: Tony
Last Name: C
City: Brooklyn
This is the only trick i know of. Grab it in your fist and pull it out. Before you leave for the ER, ask your wife/ girlfriend/ partner to clean it out for you. They will do a great job since you are injured and they will feel bad and want to make you feel better.
Don't use this trick too often though.
http://www.CostaGuitars.com
PMoMC
PostPosted: Sun Jul 07, 2013 11:33 am
Soft rubber. If you don't have a crepe block, get you one or two. They will revive most sanding belts and blocks, as well as instantly clear your reamer of chips.
You're welcome.
PostPosted: Sun Jul 07, 2013 11:45 am
I have a crepe block, never thought of using it tho. I 'll give that a try. Thanks. Clinton
PostPosted: Sun Jul 07, 2013 2:02 pm
First name: ernest
Last Name: kleinman
City: lee's summit
State: mo
Zip/Postal Code: 64081
I use recycled old dental chisels, they last forever and can be ground to any shape the job demands.Ask your dentist
PostPosted: Sun Jul 07, 2013 4:03 pm
Last Name: Collins
City: Argyle
State: New York
Zip/Postal Code: 12809
use candle wax on the flutes.
not allot-just enough so you can
easily use a toothpick to clean them.
mike
Mike Collins
PostPosted: Sun Jul 07, 2013 6:54 pm
First name: Patrick
Last Name: Hanna
State: Missouri
Yes to Mike's suggestion, or even good old Johnson's paste wax--applied to clean flutes and then buffed lightly with an old tee shirt. Not to throw water on Colin's suggestion, but all the bee's wax I've had is tacky and stuff sticks to it. Oddly enough, that makes it perfect for lots of things, such as sticking a screw to the end of a screwdriver temporarily. But I don't think it's the best choice for keeping one's reamer flutes clean.
Just my opinion, friends,
Patrick
PostPosted: Mon Jul 08, 2013 2:05 am
Candle wax sounds good, or wax paste. Thanks guys.
PostPosted: Mon Jul 08, 2013 9:05 am
First name: Alex
Last Name: Kleon
City: Whitby
Zip/Postal Code: L1N8X2
http://www.leevalley.com/en/wood/page.a ... at=1,43456 I think this replaced another product called Waxilit.
Alex
PostPosted: Mon Jul 08, 2013 11:38 am
fwiw, i use a tapered endmill= spiral flutes, 3 and 5 deg avail, carbide, no packing, -not cheap but...
